Topic: No sounds being played (FF800)
I've been using ff800 for about a month now... and I'm liking it a lot!
everything except for few issues that i'm having these days.....
i get no sounds when i play mp3 files.. it says that there is no device to play the audio file
or it may not be responding... so basically, everything that i play outside of cubase does not work.
(youtube, winamp, media player, alert sounds etc.)
i did uncheck asio direct monitoring, also set cubase preference right... (release asio driver on background)
downloaded newest driver and installed it, tried changing firewire cable and also the slot.
i'm running windows 7 64bit.. i don't know if this is a settings issue or the driver.
it's so frustrating to play music through import audio function via cubase.
i had this problem from the day one, but it was easily solved when i restarted the computer. but it doesn't do anything
anymore.
please help me out here
thanks.
