Topic: Signal vom Notebook internal soundcard to RME Madiface
I am working on a solution to use the Mic-In from the internal notebook soundcard as a input signal to RME Madiface (Total Mix).
I´m looking for this because in production situation sometimes I need a talkback solution via the RME Madiface/Madi-Muticore.
The cheapest and easiest way is using the Mic-In of the laptop internal soundchip and transferring the signal from the output of the laptop internal soundchip to the input of the RME Madiface soundcard. The signal quality is no object and I need a talkback not in recording situation but in between to recordings (to talk e.g. to the conductor).
Any other solution to put a analog mic signal in a madi signal is very expensive and high quality that I don´t need.
Is it possible at all using the internal notebook sound card output together with the Madiface? Maybe with some software like Virtual Audio Cable (VAC) or something like this ?
Until now I havn´t any success in working on it.
Thanks for hints!!
Peter
