Topic: Render same mix internally or record FF ouputs. Any difference?
Using the FF 400 and trying to understand something here. Will there be any difference between the following 2 scenarios?
Option 1: I render out my project in Cubase internally to a wav which bypasses my FF completely.
Option 2: I record the outputs of my FF to a wav playing the same project.
Will there be any audible difference between the 2? Will option 2 produce a better result since I'm capturing the sound as it is being processed by the FF as opposed to option 1 where the FF is bypassed?
What I'm trying to understand is if I'm missing out on any benefit or quality by always rendering internally and bypassing my FF.
Thank you for your help.
