Topic: Fireface 800 in Waves Rack
Hello There...
I am trying to connect 3 FF800 to an IMAC I7 Quad and so far it is not working... Cable goes from Imac to unit 1 800 port . 2 cable from u 1 second 800 port to 3 unit 800 port. The 3 units are aggregated as One unit.
There is only 1 800 port on the Imac so i guess it could be a bus overload problem ?
Next i am trying to connect the 2 and 3 unit via ADAT ports but i am not sure about the Totalmix and Matrix settings .
Anyone out there who might help ?
The end result should be 24 inserts on 24 analog channels via Waves Rack and yes the mixer is analog and the idea was to have 96 khz/24 bit res but by going to ADAT that is not an option anymore...
The theatre were i am the Head of sound are the proud owners of 7 Fireface 800 and 1 Fireface 400 but it is the first time i am trying to connect 3 together.
Best Regards
Rudi
