Topic: totalyser question
Hello, I just purchase RME HDSP 9632 and I'm very happy with it.The best sound card I ever had!
Can somebody explain what the thing circled in red is??
See the link.
http://img826.imageshack.us/i/19720790.jpg/
Re: totalyser question
Correlation meter between left and right channel. If totaly in phase, correlation is +1 if out of phase -1.
Hope it helps.
thanks
You could have just hit the key F1...
and here what we have on F1
Totalyser
This menu item brings up a Spectral Analyser with Peak/RMS Level Meter and Vector Audio Scope, see sections Spectral Analyser and Vector Audio Scope.
More information on background and usage of the analyser can be found in the section The Spectral Analyser: Theory and Usage. Information about the Goniometer can be found in the section The Vector Audio Scope: Theory and Usage.
The Totalyser is configured using the dialog Totalyser Setup (F2).
no info on correlation...................
6
Obviously the right part is the Vector Audio Scope, so you click the link to that one et voilà.
