Topic: FF800 calibration
Hi.
I resently did an I/O test on my FF800.
I'm sending a -6 dB sine wave in and out of the analog channels.
The signal coming back i peaking -6.4 dB, when it should be peaking -6.
I have has been told this most likely has something to do with calibraton. I belive it is the voltage level on the out and input channel.
It has been 1.5 years since i bought it.
Will RME take a look at this?
Best regards
Anders Laursen
Denmark
Re: FF800 calibration
Up to 0.5 dB total loss is acceptable I guess. More important is, there should not be significant difference between all input channels. As far as I know there is no user-side calibration on FF800.
3
That is not only correct but intentional. Imagine the I/Os would have the exact same level reference and then - as unavoidable - one or the other I/Os varies by 0.1 dB only, but in the wrong direction. Making an analog loop then would cause overload.
