Topic: Can I run XLR outputs from mixer to Babyface without problems?
Want to run XLR outputs from my Xone:92 mixer into Babyface - are there disadvantages?  Will going through mic preamps taint sound?  Is there a preamp override?  Any problems because they are line and not microphones?  Also, can I use XLR to 1/4" TRS adaptors to run output from Babyface and will it affect sound etc.?  THANKS!
Re: Can I run XLR outputs from mixer to Babyface without problems?
No problem, just make sure the gain is set to 0 for the Babyface inputs. As for the outs, the adapter is not going to change the sound unless it's broken.
