Topic: Strange behavior when editing channels' name in TotalMix
in the TotalMix I have noticed that when I right-click upon a grey label to edit a channel's name and close the "Enter Name" window once I've done, then I cannot repeat the same operation a second time to rename another channel... The right-click doesn't work anymore in whatever grey label I choose. Instead of opening the "Enter Name" dialog box I see several routing labels (AN1+AN2 for example) repeated in the first and second row of the TotalMix that go beyond their proper spaces. The only way to repeat the operation of editing names is to exit TotalMix app and then re-open it.
My configuration is:
Fireface 400 updated with 2.90 driver and firmware v. 1.70
iMac with Mac OS X 10.6.6 (10J567)
Is this little issue caused by something wrong in my configuration or whatever else?
Thank you for your support.
Leonardo.
