Topic: Crackling, should i buy more powerful computer?
My current setup is HDSP9632, UAD-2, Win XP 32bit, Cubase 5, PC Core Quad 2.83Ghz, 4Gb RAM, GeForce 8800GT with screen resolution 2596x1960. Latest drivers.
Have set the HDSP ASIO buffer size to 256, which gives me latency somewhere around 6ms.
Working in Cubase (8 midi tracks using vstis) - quiet often i hear crackles (this occurs not only when i move some windows in Cubase, but also in some other cases which i cannot describe). At the same time - CPU load is less than 40-50% (no spikes), RAM usage under 1.5Gb and HDD is not being used excessively.
Of course - if i increase the latency to the highest possible - problem disappears, however i suspect that it should work in 6ms with no problems?
So not sure what to do with it? Would buying more powerful computer solve this problem and allow me to have 6ms latency?
Thanks,
Marionetti
