Topic: gain structure on multiface II using outboard
Hi
I've got a question about the gain structure when I mix with analog inserts in my DAW.
I want to hit my analog master-EQ at +4dbu=0VU.
If I send -9 dBFS out from my DAW and the analog level switch is set to +4dBu on both inputs and outputs, will I then hit my master EQ at +4dbu?
/Kibek
