Topic: New Fireface UFX user. New and in need of some clarification
Hi guys,
I just got my new UFX 3 days back and am trying to work out the kinks. Im connecting it via USB to my iMac 24" with the following specs:
Mac OS X v 10.6.7
Processor 2.4 Ghz Intel Core 2 Duo
2 GB 667 Maz DDR2 SDRAM
Now i do have a question and it might be a sound a bit stupid. I tried running a few test music thru my UFX to my Genelecs via the XLR outputs. Now trying out the compressor on the main outputs on its default setting what happens is my Analog 1 output seems to come out about 5 - 6 db louder than the the analog 2 EVEN when running a test tone through logic (1k at -12db sine wave). HOWEVER this reading does not show up on TotalMix BUT it does show the difference in volume on the small LCD screen on the UFX itself. Is this some weird setting on the compressor or is there a problem with my Mac or something?? the difference is definitely audible. Is there a setting there that im not seeing. Pls note i have not very much experience with Hi-end audio interfaces and even my knowledge of audio is very limited. I have eliminated the possibilities of Cable defficiencies (USB, XLR, power supply)  I thank you for taking a time to look at my post and hopefully an answer. thanks
Re: New Fireface UFX user. New and in need of some clarification
You are using what firmware with what driver? You looked for an update?
