Topic: Making changes in Driver Panel manually freezing up host.
I seems I ran into the same issue as some other before....    unfortunately i have not found a solution yet in any of the threads about this problem.    one in particular was closed without having a solution.
here's the problem.
I cannot open the driver panel from my host application.
the temp solution which was introduced from one of the admins half a year ago works only if i close the host application before i make a change inside of the panel.
if i make the change while a VSTi is open, it will freeze the host.
is there any other "working" workaround ; ) ?
is there a fix in sight?
stuff i've noticed:
i am using win7 64
i did some tests on a fresh system with several hosts, most of them host only (not sequencer)
it seems that the issue was not there from the beginning...  it worked for a while, i could open the panel from inside the host just fine...   and probably after installing a specific software the problem was there again and from that moment on it wasn't working again in any of the hosts... even the ones which worked fine before.
i have no idea what triggered the problem again.  cubase is not on the system.
Re: Making changes in Driver Panel manually freezing up host.
IIRC, the new beta drivers resolve this issue - give them a shot unless this is a production/income machine (otherwise wait until the final drivers are released).
cool
2x SSL Alphalink MADI AX
thanks alot for the pointer....
i'll give it a try.
any idea about an estimated timeframe for the final?
just installed the beta driver.
problem seems to be solved form what i've seen so far
thanks again!
