Topic: How do I monitor when signal goes to external console ?
Just working on seting up my newly acquired FF800 - please bear with me, I know this must be basic... Used to have everything going/coming through my Yamaha 02R digital console connected to an internal PCI card so you see where I come from...
Here's the path: Guitar connected on front input 7, XLR (48volts is On, so signal flow). In Total Mix I see signal.  ADAT cables are connected (IN and OUT) to/from mixer and FF800 (no issue there when I playback).
Now, how can I get this signal hearable (in SONAR, I get signal also, so it can record, no issue there).  However, *while* I am recording this track, I want to hear it : here's probably where I am missing something.  In SONAR, Output is set to come from ADAT 7.   So again, no issue once recorded.
Of course, I could take an analog output from the FF800 and route it to an analog input of the Yamaha mixer : there, I would hear what I'm doing.  But is this the only way ? Isn't there something I must do in TotalMix so I can monitor from ADAT 7 ?  Or am I completely far out ?
Thanks,
Rob
Re: How do I monitor when signal goes to external console ?
Is your 02R clocked well ? Who is the master clock  ? The FF800 or the 02R.
Check at first in that way.
In a second way :
Open totalmix : do you see ADAT 7 level moving ? where doest it move at the top, middle, or botom ?
You have to learn how totalmixer works, without that you'll get trouble using perfectly your FF800.
Best regards
3 (edited by lanstrad 2011-04-20 18:21:40)
In a second way :
Best regards
1) FF800 is master clock and 02R is set to receive from its WordClock In.
2) I do not see ADAT 7 moving... (If there was a way I could attach a PDF here...) : On third (bottom) row of TotalMix I get AN1, AN5 and PhoneL moving (and of course In7 on the firt (top) row).  I fully agree with you I have to get a better understanding of TotalMix... I just need a quick start here, so I can avoid having to capture through old way (through 02R) as a singer is getting here in 2 days...
Ops: UPDATE -
I am starting to get it: Asio Direct Monitoring had to be active fryingpan  - But on the other hand, I heard somewhere (?) that this might increase latency ??...  Then I need to go in Fireface Matrix and click A1 7 (or whatever is ideally not used by other playback..)
At least I did it and it worked.
How about this ''Asio Direct Monitoring'' (opinions on leaving it active all times ?? - Latency ??)
Then I can probably also monitor same way on an analog output, without getting *everything* playing back (should say ''overloading and distortioning'' as I experienced yesterday...) ?
Thanks again,
Rob
