1 (edited by abret 2011-04-25 17:28:02)
Topic: Babyface/TotalMix FX : More than 3 bands of EQ on monitor outputs?
I'd like to buy a Babyface and use TotalMix FX to calibrate my monitors using EQs.
The problem is, as I understood, there are only 3 bands of EQ on the monitor output FX section.
Is there a way to use more than 3 bands EQ on the monitor outputs? Maybe by routing the signal through multiple channels?
Thanks.
Re: Babyface/TotalMix FX : More than 3 bands of EQ on monitor outputs?
No luck?
It's impossible to route the output through 2 totalmix channels?
