Topic: HDSP 9652 support in ASIO
It's not quite clear from the specifications whether the card fully support the ASIO driver.
Is it?
Thanks,
Idan
Re: HDSP 9652 support in ASIO
Yes, it does.
If so, why it is not mentioned in the specifications?
I'm a software developer, and I'm using the ASIO driver in my software, so I'm afraid it might not work with the card...
One more question - I can see that part of your cards support "ASIO Direct Monitoring" (such as the FireFace UFX). Can you explain the difference? Is it still fully support the ASIO driver?
Thanks,
Idan
Any idea....?
