Topic: Problem : Fireface UC - new TotalMixFx
I have a little problem with my Fireface UC that I did not have before with the old driver. Let me explain, I use cables for my speakers a little too large to be able to plug in 1 and 2 outputs , then I plug them in 1 and 4. And before, I could create a link between them, but not now. I read in the PDF TotalMixFX that the hardware outputs were always Stereo but it was not the case before in the old driver.
Is there a new way to do it, a different routing in the matrix?
Or maybe a change in the driver?
Thank you for all suggestions
F@t2
2 (edited by F@t2 2011-06-03 14:23:37)
Re: Problem : Fireface UC - new TotalMixFx
nobody has answered. Perhaps you didn't understood my problem.
http://img709.imageshack.us/img709/4154/rmemixer.jpg
How about a fader group for 1 and 4? The output channels can be set to mono in the beta versions of the USB windows driver: http://www.rme-audio.de/forum/viewtopic.php?id=10506 (Post no. 29).
best regards
Knut
Correct driver link:
http://www.rme-audio.de/forum/viewtopic.php?id=11209
Ok thank you for the solution!
I finally found how to link my Faders.
!!!!    You must click on the Fader with the Shift button to switch from the color white to yellow.  !!!!
Thank you to all the RME team, you are doing good work!
wink
6
Well, that's both in the online help and the manual. But Knut's point was that you can have mono channels in the output section now, like with the old TM, if you use the latest version. Then you can link 1 and 4 again.
7 (edited by F@t2 2011-06-05 20:48:24)
Yes, now all my problems are solved. ( sorry for this stupid question, i don't see this tips in the manual )
But now all is ok, i have exactly the same settings as the old TM. :-)
http://img17.imageshack.us/img17/4199/rmenewmixer.jpg
