Topic: Global record with digiface
Hey all,
I have a very urgent questions (it's for a live recording I'll have to do tonight... wink).
I have a Digiface with 3 ADAT ins from two OctaMic II and a swissonic A/D. Basically, everything works fine. I.e. TotalMix works, I see and hear the input signal, I can record all inputs within a sequencer software etc.
However, the global record function of DIGIcheck doesn't seem to work with it. In the ASIO driver select field the only option I get is "ASIO Hammerfall DSP" (which I guess is fine). However, the only device I can select is "HDSP MADI"... and neither "Input" nor "Playback" works. It also says "No device running." in the status bar.
Can anyone help me to set this up correctly?
Thanks a lot in advance!
Cheers,
Wolfgang
PS: Don't know whether this is important, but so far I've always used DIGIcheck with my Fireface UC. It's the first time I tried to use the digiface...
Re: Global record with digiface
Outdated drivers or outdated DIGICheck.
outdated drivers....!!!
Should've thought of that myself... *shame on me* wink
My colleague mistakingly installed a driver from 2005...
Thanks a lot for your really quick answer, it made me find the problem! The recording turned out superbly! Global record definitely rules! big_smile
Wolfgang
