Topic: RME Babyface: Pop sounds
i´ve got a problem with my new babyface.. so when i press the play button on my cubase 5, now and then there are some pop sounds.
Is it a generally problem with the drivers or a setup problem or is my babyface damaged?
Thank you smile
Re: RME Babyface: Pop sounds
Sounds like the play buffer of Cubase is not empty and releases the content to the driver before it fills the buffer with samples from the current cursor position.
So what I have to do to fix the problem?
