Topic: Phantom power on/off by encoders
Hi All,
I just became a proud owner of FF UFX a couple days ago, and just checking/learning various functions.
I couldn't find how to turn on/off phantom power from encoders on the unit itself. I checked this forum, and FF UC also is not able to turn on/off phantom from the unit. Is it still true? Then, is UFX in the same situation?
I'm planning to use UFX as a standalone location recorder, after reading its ability to record directly to USB flash drive. I'm very excited about the idea!
I can probably leave phantom power on before taking it to standalone mode, but if I forget to do that, and I go with bunch of condenser mics to the place where I may not have computers...then I would be in trouble. Don't you think?
It seems so obviouls question, and if it's been addressed many times, my apology first.
Thanks for the help.
Re: Phantom power on/off by encoders
This is possible:
1) Press channel button
2) Switch to the desired mic channel
3) scroll down to 48V
best regards
Knut
No wonder I was browsing Mic/Gain button.....
All right, so far so good... I found it. I'm so excited to use UFX as my mobile rig!
Thank you so much!
Cheers
For the record, this is not a good idea.  Plugging in mics (or unplugging them) with phantom power already engaged can damage them.  Need to hook up mics first, *then* switch on phantom power.
5
It can also damage the mic inputs of the (any) preamp. They have a protection circuit but better not let it do their job in the first place...
Yes, I was worried about that when I checked some old threads about the use of FF UC in standalone mode, and phantom on/off with the encoders.
Now with UFX I found I can do phantom on/off without computer. I'm so happy with UFX, but UC also now?
