1 (edited by gato 2011-05-16 17:14:19)
Topic: Babyface (master) + 003 (slave) via ADAT ?¿
The ADA8000 is working just fine when setting the clock to internal.
The Baby says the 003 through ADAT is not working (blinking) with the same configuration.
So,
Do I need to set the clock to EXTERNAL or this would result in the 003 as the master?
Or maybe I need to use a Word Clock cable to be able to record more inputs with the 003?
