Topic: Fireface 400 with AIC driver for midi
Does anyone know how to set up the midi interface on a Fireface 400 to use the IAC driver instead of Sscom 1 or Sscom 2 ? Is it possible to do this?
RME User Forum → FireWire & USB series → Fireface 400 with AIC driver for midi
What are you talking about?
I am using a product called Softstep which is a footswitch midi controller over USB. It requires that it and only it use Sscom 1 and 2 for midi. I am having a conflict with the Fireface 400 with it because as far as I can tell it uses Sscom 1 and 2 by default. So I want to reroute it midi functions to use ports on the IAC instead. Hope that makes sense.
