Topic: RME 9652 with SSL Alpha Link & PT9 new to RME, help needed
Hey guys,
just got a RME HDSP 9652 and I'm trying to hook it up with SSL Alpha Link Madi AX
on PT 9, Windows 7 Home Premium
Intallation of the RME card went smoothly, PT sees all the IO just fine, problem is, I've never used the
Totalmix and I sense most likely there is where lies the rub.
I have all the 24 IO of the SSL connected to two patchbays, with all the pres and ouboard already
SSL Alpha is connected with the 9652 via ADAT, (all 24ch, so ADAT IN of the SSL into ADAT OUT of the RME and way back)
I can see analog signal running thru the SSL from the preamps, and I can see the the analog outputs showing signal on the SSL as well.
But PT won't record anything, nor it will show signal in the meter section while recording.
Anyone who can walk-me-thru the setting of the three?
Thanks in advance
EDIT: SSL is default from the factory, SSL is master clock but I'm not connecting it to the RME thru the BNC, just Adat, is that gon' be a problem?
Do I *need* word clock BNC cable?
