Topic: BabyFace / TotalMix: Quicktime Player 10 records only mono
I use a BabyFace (v179) together with TotalMix (0.93 MAX OS X) to create a stereo mix down of different sound sources. I use the loop back function to record the result using an external recording program.
When I use Cubase 5 or Wavlab Elements the result is recorded in stereo as desired.
When I record the result with Quicktime (New Screen Recording) then only mono is recorded.
Any ideas, what I could do?
Thanks,
  Gabriel
Re: BabyFace / TotalMix: Quicktime Player 10 records only mono
As far as I know Quicktime is designed to record a mono signal from a mic.
best regards
Knut
