Topic: featuree request..loopback offset ..
Hello..
i use the loop back feature latey a lot to transfer audio data between daws that run in timecode sync..
problem..all latency compensations reffer to a AD/DA loop back..t´so internl rme routed material arrives way to early..what makes a lot of extra work..would be nice if my computer > the rme driver could handle that in form of an option that delays loopback audio just with the amount the AD/DA conversion thru the fireface would take ..so evrything just arrives in the daw with the same offset.. would be comfortable .
Re: featuree request..loopback offset ..
Simply not possible. There is no memory to delay the digital data. And the offset signalled via ASIO is global and not per channel.
You should be able to offset the timing manually in your DAW. At least Ableton Live (which I know you are using) allows for that even on a track by track basis (Delay parameter below each track).
