Topic: TotalMix bug.
when you hide Input, Playback and Output it breaks. ( snow leopard )
the whole window disappears and becomes just the top bar.
resizing is not possible. ( vertically at least. )
I had to search for shortcuts to select different presets to solve this. So if you want to see the bug you'll need to press Alt-( 1-8 ) to get out of it.
OTHER BUG...
when saving one preset to another location it retains the name of the location you got it from. ( make sense? )
basically when using preset 1, click save, then click preset 2 then when you mouseover 2 it displays 'preset 1' and when you select it the header says the same.
Re: TotalMix bug.
What else should it say as you did not edit its name?
Re: TotalMix bug.
hehe, sorry, in my rush to get recording and read as little as possible, I didn't realise you could name them!
have you tried clicking input, playback and output panels off? It may as well keep the window visible so you can still select presets.
Mac OS 10.6.7
thanks again
Re: TotalMix bug.
It has been like that forever and will not change anymore.
Re: TotalMix bug.
Speaking of "bugs", I think I found one. I noticed this odd behaviour recently with the pan sliders jumping semi erratically. This is with the latest 2.91 driver and OSX 10.6.7 (though it happened on 10.6.6 also).
You can see it happening Here.
6
Re: TotalMix bug.
Same under Windows. When the mouse moves out of the window contact is lost. On our list, but has no high priority at this time.
Re: TotalMix bug.
OK. Good to know that it's not isolated. Thanks.
