Topic: Hum on babyface when rode nt1000 is hooked up.
I got some hum noise that is very exstensive when i hook it up to babyface and my mbp.
I turned on the phantom power, and everything should work, but isnt. Cant get no sound from it at all.
I do however get an sm beta58 to send signal an record with, but not the rode.
Is the usb providing to small numbers of power to it, so that i have to hook it up to the outlet or is it a "monday" card that i got a hold of?
Best regards Greger Lindberg
Re: Hum on babyface when rode nt1000 is hooked up.
Do you get hum when you plug the 58 in? It sounds like you have a broken mic lead. Can you test it or try another cable?
Isaac P
No hum with the 58.
And the same thing with other cables. It works fine on my FF800 for some reason. But on the babyface it doesnt...
