Topic: Babyface Capture Device Service has stopped working
Now after the latest update I get the following message:
Windows can check online for a solution to the problem.
-> Check online for a solution (recommended)
-> Close
Problem signature:
Problem Event Name: APPCRASH
Application Name: DevSvc.exe
Application Version: 1.0.0.1
Application Timestamp: 45ebd4db
Fault Module Name: ntdll.dll
Fault Module Version: 6.0.6001.18000
Fault Module Timestamp: 4791a783
Exception Code: c0000005
Exception Offset: 000606cf
OS Version: 6.0.6001.2.1.0.256.1
Locale ID: 1054
Additional Information 1: fd00
Additional Information 2: ea6f5fe8924aaa756324d57f87834160
Additional Information 3: fd00
Additional Information 4: ea6f5fe8924aaa756324d57f87834160
I'm under Windows Vista x64
However, the BF seems to still working normally but I want to know why this message always appear when I connect the BF to the PC, was it because I didn't update the drivers properly? Or was it that I removed the drivers before I even use the new one (or vice-versa), I remember clicking on that "remove old mixer autorun" file in the latest 0.9.81.0 zip folder. How do I fix this issue? Thanks.
