Topic: AES/EBU to spdif cable recomendation. FF UFX
I bought two 5m 110ohm AES/EBU cables and made two (10cm cable) xlr to chinch adapters according to the FF UFX manual. I use them with TC Helicon Voice Live 2, but I get drop outs quite often @44.1KHz, @96k they occur less frequently. I have checked that the TC gets a clean signal, and analog output from it does not contain artefacts. I have also connected VL2 to a TC Konnect Live using 75ohm 3m spdif cables and everything is fine both 44.1k and 96k.
Any recommendations on interconnecting AES interface on FF UFX to Spdif? Max cable lenght? Best XLR/Chinch plugs?
Is a AES/Spdif converter needed for distances like 5-10m?
