Topic: Loopback problem
I've been having a weird issue with the loopback function on a Fireface UC.
Loopback works fine if I use the analog I/O, SPDIF (optical or coaxial) and ADATS 1/2, 3/4, 5/6 but is mono left only and fails on me when using the ADAT 7/8. BE AWARE : I am using the optical output as SPDIF at the same time as using the ADAT channels for loopback which is probably why the issue occurs.
It looks like a counting bug ?
check : www.audiodude.nl/Pics/rmeprob.jpg (screenshot)
Can anyone confirm ?
Arjan Sinnige
Bug has been there on the last few drivers. I'm using the driver 983 Windows 7 SP1 x64 firmware 115.
Pro-Found Recordings & SAE
Owns:Hammerfall9652,Multiface I,2xADI-8 Pro,Fireface UC.
