Topic: FF400 and two ASIO application gives noisy output
Hi all.  If I run one application (such as REAPER) using ASIO and the FF400, the output is great.  If I run two applications at the same time (such as REAPER and Wavosaur), most of the time the output is garbled and noisy.  Occasionally though it sounds fine.  Is there some way to get two applications to "share" the FF400 consistently? Thanks!
Re: FF400 and two ASIO application gives noisy output
Which driver version are you using?
