Topic: Rme Fireface 800 and Focusrite Optopre Platinum
Hi,I want to connect with Focusrite rme ff800 with target Optopre .... I want to connect to digital Adat.
Also need the word clock cable?.
Greetings to all :-)
Re: Rme Fireface 800 and Focusrite Optopre Platinum
With the Octapre MKII- You should use word clock. So you will need 2x ADAT cables and 1x WC cable.
http://www.focusrite.com/answerbase/en/ … hp?id=1053
Octapre MKII Dynamic -  You can use either word clock or use ADAT.
http://www.focusrite.com/answerbase/en/ … hp?id=1080
Set the RME FF800 to Master/Internal clock and make sure that the SPDIF In is not set to optical.
Thanks Chris
Chris Ludwig | ADK Pro Audio
www.adkproaudio.com
https://www.facebook.com/adkmg
