Topic: FF 400 no longer detected on Mac
Hi everybody,
my FF400 was working problem-free (driver vrs.262a) with my Intel iMac (purchased June 2010), until a couple of days ago. I wanted to update the driver (from vrs.262a to vrs.275 and later to the newest vrs. 292) and therefore first uninstalled previous driver by removing (trashing) the following:
/Applications/Fireface Mixer
/Applications/Fireface Settings
/Library/Audio/MIDI Drivers/Fireface MIDI.plugin /System/Library/Extensions/FirefaceAudioDriver.kext
/Users/username/Library/Preferences/Fireface folder /Users/username/Library/Preferences/com.rme.FirefaceMixer.plist
/Users/username/Library/Preferences/com.rme.FirefaceSettings.plist
/Library/LaunchAgents/com.apple.rme.firefaceAgent.plist
Again, my FF400 was working problem-free for a year with driver vrs.262a –without- me having to use its power supply. For this connection I have been using a Firewire adaptor (9 to 6 pin) attached to a 6 pin Firewire 400 normal cable which was then plugged to the right Firewire 400 input of the FF400 (the second on the right of the Fireface’s power switch that is – this is where it was working fine for a year now). After updating the driver by installing vrs. 275 the red light (host) remains always on and the Fireface mixer and settings are not functioning.
At first I thought that the 9 to 6 pin Fireface adapter was faulty, so I got a new 9 to 6 pin Firewire cable and tried the connection again without an adapter. Unfortunately the problem persists. My Fireface 400 cannot connect to my iMac and the “host” light remains red. I have tried to connect to both Firewire 400 inputs of the Fireface 400, no luck. I have also tried to connect the power supply of the Fireface 400 then connect to the iMac. No luck again, nothing worked. This is when I looked at the RME Forum and read several posts, like i.e.
http://www.rme-audio.de/forum/viewtopic.php?id=4986
or
http://www.rme-audio.de/forum/viewtopic.php?id=974
where it became obvious that there is a hardware issue with the FW controller/chip from Agere for -some- iMacs.
BUT, as this has never been an issue for my iMac and my FF400 was working problem-free for a year this cannot be the case. Therefore those FW800 hubs and Lacie external H/D workarounds mentioned in the forum’s posts do not apply as my FF400 was working. The problem should be somewhere else. I suspect it could be S/W orientated. Am I missing something?
I have send a support inquiry to RME and got this reply:
"Hello, after updating the driver, did you also update the unit's firmware?
RME"
Does anybody know how am I supposed to update FF400's firmware when my iMac does not "see" it at all? When I try to update the firmware, it tells me that there is no Fireface device or driver installed.
What I did is (again) uninstalling the driver vrsn. 275 (by removing/trashing the files at locations listed above) and installed previous vrsn. 262a (where everything was working fine before). Unfortunately, no luck. Red light on, no FF400 communication with my iMac. I’m installing every driver “by the book” (Read Me’s & User’s guide) so what’s happening here doesn’t make any sense.
I would be grateful for a solution reply while waiting for RME's support reply on this issue.
My iMac system:
Mac OS X 10.06.7
Model Name: iMac
Model Identifier: iMac11,1
Processor Name: Intel Core i7
Processor Speed: 2.8 GHz
Number Of Processors: 1
Total Number Of Cores: 4
L2 Cache (per core): 256 KB
L3 Cache: 8 MB
Memory: 8 GB
Processor Interconnect Speed: 4.8 GT/s
Boot ROM Version: IM111.0034.B02
SMC Version (system): 1.54f36
Graphics: ATI Radeon HD 4850
Many thanks in advance.
Bellerophon.
