1 (edited by Zavieri 2011-06-23 19:38:34)
Topic: Snapshot and playback channel bug - TMFX UFX
There is a bug in TMFX when storing/recalling snapshots:
I have a 15 ch. recording all playing back in mono mode on ch. 1-15:
Playback ch.1 -> ch. 1 (AN1)
Playback ch.2 -> ch. 2 (AN2)
Playback ch.3 -> ch. 3 (AN3) etc.
When I store the snapshot to a free slot e.g. mix 2
Change the snapshot to e.g. mix 1
Recall snapshot mix 2 i get:
Playback ch.1 -> ch. 1 and ch.2
Playback ch.3 -> ch. 3 and ch.4
Playback ch.5 -> ch. 5 and ch.6
One more thing, mix 1 is a clear stereo mix (all first row input ch. are stereo).
Fireface-UFX, Mac OSX 10.6, Logic 9, BCF2000, AC-7 user, vocalist, live sound recording
Re: Snapshot and playback channel bug - TMFX UFX
Can you please send me the workspace including those two mixes?
Simple playback, fails to maintain the channel numbering when switching between mono and stereo. There's the workspace:
http://www.easy-share.com/1916333827/pl … 0mono.tmws
The same happens when a stereo channel with playback set from ch.1/2 is changed to to mono mode:
playback 1/2 - > AN 1/2
change to mono:
p. 1 -> AN 1
p. 1 -> AN 2
instead of:
p. 1 -> AN 1
p. 2 -> AN 2
5
We are not able to reproduce any wrong behaviour or 'bug', even with your workspace. From your last description it seems you changed mono/stereo in the hardware output row, while the option 'Center Balance/Pan when changing Mono/Stereo' is active. That leads to a centered pan and would cause what you describe.
By "playback ch." I meant "usb playback ch." selected from the record view.
