Topic: HDSP AES 32 card generate a Memory Parity errror
When I place the card in a HP8100 computer ,after a while (30- 60 min) the screen turns blue with following message:
NMI: Parity check/ memory Parity Error. I switched the card in into a compaq computer and it runs perfect for days. Then i put it in another HP8100 computer but the same error appeared also on this machine. Is their a logical explenation for this problem and does anyone have a solution?
Robin
Re: HDSP AES 32 card generate a Memory Parity errror
Firmware and driver version of the AES-32?
I found following information on the driver CD
Driver version V 2.95 (01/30/2009, current firmware: 2.70 / 2.47 / 1.67)
I use XP Professional as OS.
Robin
