Topic: Ff800 loopback problem
Hi all,
I have a problem with my fireface 800:
I'm trying to record a submix via the loopback function, i ctrl+click on the white label on the third row and it turns red but if i try to record on the same channel i have no input. What i'm missing??
I'm using os x snow leopard + live 8.2.2
Thanks for the support and for this great interface
Re: Ff800 loopback problem
That's pretty much all there is to it... which channels are you using for the loopback?
Channel 13-14 and i'm using firewire 400. maybe in this case i have only 10 in/out???
Check your "Limit Bandwidth" setting in the Fireface settings application. It has to be set to either "Analog + SPDIF + ADAT1" or "All channels"
Now it works, i turned on the mac and set the ff800 preferences to all channels.
Thanks very much!!!!
