Topic: New Motif XS Rack setup in my current system with my FF400 - Cubase 5
Does anyone have a XS Rack that they use with their FF400?
I am not clear from the XS Rack Owner's Manual pg. 17 , how i should be setting it up with the rest of my gear.
Right now I have my Korg TS MIDI In and Out connected to my RME FF400 MIDI Out and In which then connects
to my PC via the IEEE1394 firewire.
There is a NOTE in the OM on this page that states,
"When using an external keyboard to play the MOTIF-RACK XS sounds while connecting the MOTIF-RACK XS to a computer, you’ll need to use the MIDI Thru function of the DAW software on the computer to re-transmit received MIDI data to the MOTIF-RACK XS (Port 1)."
I will make this change in Cubase. but after installing the necessary USB Driver and XS RACK SW onto my PC, can I simply connect the XS RACK to my PC via a USB cable?
Is the fact that my PC is connected to my FF400 via firewere mean that I will also be able to hear the audio from both my Korg and the XS Rack through my headphones and/or monitors, which are directly hooked up to the FF400?
thx,
ciao, Dan
