Topic: HDSPe MADI + SSL Alphalink + Ferrofish A16MK
I'm trying to make these 3 work together
- SSL works fine, now clocked via workclock
- the A16 gets the embedded madiclock and locks to madi
- the RME HDSPe Madi is master
now i got the follwoing issue
- the SSL has madiports 1-24 (i think this is hardwired and can't be changed?)
- the Ferrosfish should be able to work on Madi 1(1-16) Madi 2 (17-32) Madi 3 (33-48) or Madi 4 (49-64)
However i can only have it to output on madi 1 (overuling the SSL) selecting 2,3,4 provides no signal the the HDSPe's input in totalmix. both the MADI link and lock stay green on the A16MKII
(now connected as backup via the adat of my Raydat, as projects need to be finished, but this should normally work right?)
Thoughts?
