Topic: card bus doesn't fit into ner macbook pro quadcore
I have an the first Hammerfall DSP Multiface that works with laptops.
The configuration/width of the cardbus is wrong/too wide for the cardbus slot in the new
macbook pro quadcore.Is there any sort of adapter out there I can use or am I out of luck
all together and should sell the Multiface?
Thanx,
hughburrows
Re: card bus doesn't fit into ner macbook pro quadcore
This is not a Cardus slot, but Expresscard (only on 17" MBP). Exchange the the Cardbus card with this and you can continue working with your MF: http://www.rme-audio.de/en_products_hds … sscard.php
Thanx a lot for the info.
Do I need to purchase the expresscard or can I exchange mine for a new one?
Thanx
hughburrows
No, you can't exchange it, sorry. You may be able to sell it on ebay or similar.
