Hi Chris
Thanks for that. By the way, I'm a happy ADK customer here in Scotland with one of your Quad Xtremes :-)
I normally use 44.1k. For future reference, what would my limit in terms of sample rate using a FF400/UC viat adat to a MultifaceII set as master?
I must say Chris, I'm intrigued by the flexibility in which a Fireface400/UC may bring to my setup. Not sure which I'd go for as I'm not too sure if my laptop's firwire is TI chipset. I'd need to check somehow.
I'd never thought of a FF400/UC for some reason. I'm not sure how the headphone output of the FF400/UC figures as anologue outputs 7/8 and how these can be used as anything but headphones (insert cable perhaps?). However, I reckon 14 routable outputs in my patchbay would suffice. Also, the unit would be directly below my patchbay which comfortably enables me to patch into the 4 line inputs on the FF400/UC's front.
Thanks for putting me onto this. I have a couple questions which I hope can be cleared up before I order.
1. In the setup you described Chris, would I basically have a FF400/UC's analogue inputs and outputs brought into my MultifaceII's TotalMix via adat 'without' having to hook up the FF400/UC to my PC using its IEEE 1394/USB cable? Therefore, assuming this is correct, the only connections a FF400/UC would require would be the 2 x toslink cables from its adat I/O >>> MultifaceII adat I/O? Apologies for being over descriptive, I just want to be sure.
2. In another setup scenario, would I be able to use a FF400/UC hooked up to my PC using its IEEE 1394/USB cable alongside my MultifaceII, both as separate sound cards working side by side (albeit in separate TotalMixes)? The reason I ask is that their manuals each state that up to 3 HDSP or 3 FF400/UCs can be used. However, the manuals do not state whether or not 'one of each' can be used in a given setup. Incidentally, I use Sonar X1 64.
If my second question is dooable, this would expand my capacity further (if/when needed) by then having 16 x analogue I/Os, 16 x adat and 4 x s/pdif. Fingers crossed. HeadScratch
Kindest Regards
LiD.
