KoleThomsen wrote:Hi all,
Strange problem.
I can record for 2-10 minutes and then OSX freezes completely.
I've searched and found a couple of forums with people posting about the same problem, but no solutions was apparently found.
Madiface firmware's updated to the latest revision 11.
System specs: MacBook Pro 2,66 GHz Core2, 4 GB RAM, 7200 RPM HD, OSX 10.6.8, newest Reaper (tried in Pro Tools 9 as well, same problem).
It's not the system, i can record perfectly fine with my two other soundcards.
/Kristian
I haved the same problem, with a similar mbp but with 8 gb ram. Maybe I've solved the problem, but I'm not sure exactly where the problem is.
This was my procedure:
Open the Console (in Utilityes), connect your Madiface in the pciexpress slot. Run first reaper and see what appears on the Console screen. There appears a lot of errors, and it depends from many QuickTime codecs that could be obsolete. In my setup I've found, and removed, this: 3DXQuickTime.component, LiveType.component, Sonix SN9C102p WebCam.component. They resides in root/Library/QuickTime.
This don't solve the problem immediately, and I get always a mbp freeze....so I restart and then I've run ProTools...first error was a try from ProTools to open a Rewire plug at 64 bit that resides inside the content folder of my Reaper 64 bit version...so I've deleted the Reaper 64 app. Then another bunch of errors occours in ProTools launching his firewire and usb audio and device drivers, like: DigidesignFireWireMIDI.plugin, DigidesignMbox2Midi.plugin, DigiDIOMidiDriver.plugin, M-Audio USB Support.plugin, and I've removed also the YamahaNuageMIDI.plugin. This resides in root/Library/Audio/MIDI Drivers. I've let in place only the HDSP MADI MIDI.plugin, PaeFireStudioMIDIDriver.plugin, Yamaha-USBMIDIDriver.plugin and the YamahaNetworkMIDI.plugin. Some other plugins could be found in the user/Library/Audio/Midi Drivers location.
At the end of this, after launching the ProTools app, I' spilled off the MAdiMIdi port in ProTools.
Now it seems that the Madiface is running correctly, in Console I' don't get any errrors. I've only to try a full recording with the Madiface connected to a Digico SD8 console in the next days. Now to try it out I've connected the Madi buss with a bnc from the in to the out connectors.
What I suppose, is that the MAdiface get a mbp crash due the Midi drivers mismatch, or maybe a midi loop. And maybe RME has to investigate, solve this problem and release a new firmware/driver update, also for us users of the 10.6.8 osx
Please give a try to my solution and let me know if it solve the freeze of your mbp. Remember, I have deleted only the Reaper 64 bit version, all other driver are to move to new folders outside the originals.
Best regards
Italo
