Topic: HDSP 9652 PT9 Window7 - random I/O loops problem
Hello guys,
after enjoying for few months a very smooth system with Windows 7 32 bit,
Pro Tools 9, HDSP 9652 connected with SSL Alpha Link Madi AX (24 channels connected via ADAT, clock via BNC, SSL Master, RME Slave)
today during a mixing session I had the weirdest problem:
completely random feedbacks loop on completely random channels.
Opening the RME mixer shows signal loops in again, random channels, 5/6, 11/12, 7/8 etc..
I noticed because on one channel I had one of my 1073 hw eq in insert and while playing the mix
i was hearing click and pops. Muting all channels revealed them coming from ch 7, bypassing the hw made it stop.
So at first I thought it was a problem with the hw itself but soon I realized that it was doing it on several channles.
I deleted preferences on PT, I restarted the machine several times, I loaded default setting I/O on PT
I opened a totally new PT project with default setting (after deleting preferences and database)
with just one stereo channel and the master channel and still, the RME mixer is showing loops everywhere and
as soon as I put an hw insert involving one or more of those channels audio is cut out intermittently,
plus clicks and pops like no tomorrow..
Absolute nothing changed in the system since yesterday (which was fine),
it was the same project, the same mix (altho' like I said I tried in other projects, both existing and new)
24 hours difference and the problem popped up..
What this could be cause by? Drivers? W7? PT9?
I'm in the middle of a mixing session for an album and this *definitely* it's gonna be a major problem.
When I first installed the system/PT9 I had the same problems at first, which magically disappeared on their own
It seemed PT, I say this because looking at the RME mixer all the loops/feedback disappear as soon as you close PT.
Meaning, definitely there's no hw connection problem, no hw loop (the system ran smoothly for months anyway),
it's definitely software related. Seemed like PT I/O were somewhat messed up but like I said,
everything was mapped perfectly and they just went away on their own.
Now I can't relay on luck here, I need to find the source and solve the problem hmm
Any help would be much appreciated
thank you all in advance
Re: HDSP 9652 PT9 Window7 - random I/O loops problem
Anyone?
I don't work with protools but I read ina forum here that after updating PT or a driver you need to completely reinstall PT from scratch. You could try that....I know not attractive.
4 (edited by NewtoRME 2011-08-04 18:47:19)
I didn't update anything, absolute nothing is changed from the day before when everything was ok
this is what I get when opening PT, NO playback and NO signals of any kind are going on
nor in the hw domain nor from PT
http://img820.imageshack.us/img820/7426/wtfvh.jpg
I tried disconnecting the BNC cable and clocking RME/SSL via Adat, the problem is still there
both with RME or SSL as master.
So this could suggest is not a clock problem.
Some setting in the totalmix? It's default preset one in all the tests.
Reinstalling RME drivers? All this makes very lil sense to me
5
Remove the HDSP 9652, clean its PCI gold contacts with a rubber pencil/eraser and reinsert it.
Hey Matthias,
thanks, I'll try that and report
Ok I cleaned up the contacts as suggested, and since they looked pretty clean and oxide free
I also swapped the card on a different PCI slot to see if anything changed and while doing all of the above
I might found the real problem, now, it's saturday so I can't check it out but I found out ONE ADAT cable
connecting the RME to the ALPHA seems to be broken.
By removing the card and then connecting everything back i noticed ADAT 2 was showing NO LOCK
in the RME panel, so i checked the connections and they were inserted correctly,
i then started swapping the ADAT cables and after trying all the possible combination
it was obvious that ONE adat cable wasn't passing signal (put it in the ADAT 1 was breaking that group of channles,
putting in ADAT 2 was breaking that one while the 1 was ok, and so on..)
So, for sure that cable is faulty, but looking at the picture I posted you can see
the feedbacks are not limiter to the first, or second or third 8 groups of channels,
meaning, not limited to an ADAT group only.
My question is (just out of curiosity since on Monday when I get a new cable I will have proof/answer ):
could that one faulty cable be the cause of the feedback problems? on the other channels as well?
Could that cable mess up the whole system?
Just in case someone else runs into the same problem,
it was the adat cable, it was messing up everything.
