Thanks MC: here's the report.
With "Optimize Multiclient Mixing" Enabled:
- With nothing playing, the HDSP driver reports 256 samples (5.80 ms), and the Centrance software reports 546 sample (12.38 ms) (input + output no doubt).
- Starting WDM then starting ASIO: sound from WDM but no sound from ASIO. Attempting to read the latency with the Centrance software results in a different value every time: 19604 (444.54ms), 422 (9.12ms), 3728 (84.54ms), 406 (9.21ms), 262 (5.94ms), etc... it never is the same. However apart from the pop generated on the read, the WDM playback seems unaffected by these changing latency values.
- If I stop WDM playback, ASIO still doesn't sound. Interestingly, Centrance tells me it "Can not measure the latency, please check your connections..." I'm using the MF's internal loopback to run this test so nothing's changed.
- If I then reset ASIO, ASIO sounds and I get a consistent 546 samples (12.38ms) of latency.
- If I then restart WDM playback, I hear both WDM and ASIO playback. The Centrance software reads the buffer size as 546 samples but about 50% of the time it reads other random values < 546 samples.
With "Optimize Multiclient Mixing" Disabled:
- As before, with nothing playing, the HDSP driver reports 256 samples (5.80 ms), while the Centrance reports 546 samples (12.38 ms).
- Starting WDM, buffer readings are the same.
- Then starting ASIO: sound from WDM but no sound from ASIO. As before, attempting to read the latency with the Centrance software results in a different value every time.
- On stopping of WDM playback, ASIO playback immediately starts with high latency. And the Centrance software reads a consistent 16930 samples (383.90 ms)
- If ASIO is reset, latency is now down to 546 samples (12.38 ms) on every Centrance read.
- If WDM playback is restarted: both WDM and ASIO sound and the buffer size remains mostly consistent at 546 samples (12.38 ms); one reading out of about every 8 will be lower, and not consistently the same.
<whew!>
MBP = HDSPe Expresscard: MF1
