Topic: Multiface II not syncing properly to master via s/pdif
My multiface II (connected to a hdsp expresscard) doesn't seem to be syncing to my master clock (rosetta AD) via s/pdif properly. Multi channel recordings sound very strange so i set up a test with the same signal going to rosetta L in and multiface in 1 and they seem to be going at exactly the same rate but the Multiface AD's are a couple of samples behind the Rosetta AD at all times.
My plan was to use the Rosetta and Multiface together for 10ch AD but this currently produces unacceptable results (Imagine a drumkit with the close mics a couple of samples behind the overheads).
I can of course compensate for this lag in various ways but i'd rather find out what the problem is.
thanks
/Tobias Eklund
