Topic: Using A Focusrite "VRM" Box
I'm using the UFX as my interface and the VRM box must have a SPDIF input feed in order to be used along side the main interface. The UFX does not have a SPDIF output... I have a Saffire Pro 40 sitting around and I'd like to use the Pro 40 to interface with the VRM box by coming out of the UFX via Adat into the Pro 40 and then SPDIF out of the Pro 40 into the VRM box.
So, I have it connected in this manner now...So, what setting should I make in Total Mix to get the signal showing up in the VRM box? The on screen window for the VRM box is showing that the SPDIF signal is locked.
