Topic: Clicks and pops, asio meter spikes in Cubase 5 with FF 400
Hi !
I have a problem with my system, and i hope someone can help me here:
Got an RME FF400 soundcard, curently using Cubase 5 and in the VST Performance meter the ASIO meter it s going crazy when i run a couple of VST s, Even if i run at high buffer size like 1024 sample the same thing happens.....I can listen to music in Winamp with no problem, and record guitar DI tracks in Cubase, but when i apply a couple of vst effects the clicks starts....
Computer specs are the following:
Windows 7 64 bit
Gigabyte MA785GT UD3H Motherboard with onboard TI FW chipset
AMD Phenom II X4 955 CPU
8 GB DDR3 RAM
Radeon X 1300
WD 7200 rpm 500 GB HDD
What should i do?
Suggestions?
