Topic: Totalmix routing 8 out of maschine soft to 8 ins ableton live
Hey, my firt post on this forum.
Looking for a new audio interface, interested in the ffuc or babyface.
I'm intrigued by the total mix software.
I've read a bit about its routing capabilities and loopback feature.
However, I'm not sure yet it will perform what I want.
For the moment, I use soundflower or jackosx, so I can virtually connect 8 outputs from a software to 8 inputs in my daw. It does work but I also need to use some ins and outs of my audio interface so I aggregate the whole thing and it becomes unstable...
Anyway, will totalmix bring me the option to connect virtually my outputs from one software to unother one?
Can I connect virtually more than one software (like 8 maschine outs to pro tool and 4 outs ableton live to pro tools as well?
How many virtual connection an I make? In soudflower it is 16, and with jack I believe it's unlimited. What about totalmix?
Lastly, if virtual connection like the one I described are possible, should I expect any latency?
Thank you !
Re: Totalmix routing 8 out of maschine soft to 8 ins ableton live
The Firefaces can route hardware output to hardware inputs (as if you were using a loopback cable, but without AD/DA conversion in between). So the number of loops is limited by the number of outputs/inputs (each output loops back to the input of same number, i.e. out 1 -> in 1, out 2 -> in 2 etc).
Why are you using aggregation anyway? Just have jack/soundflower for in/out (routing the hardware I/Os through jack/sf).
3 (edited by The Carpet Cleaner 2011-09-12 17:27:57)
Timur, thanks for your help mate.
ok so I think I understand now :
the fireface UC got 36 channels in total so it's 18ins/18outs
So let's say I use 2 analogs inputs and 4 analogues outputs. That leaves 14 channels to do virtual connections. I can for example route 4 channels of maschine to outputs 5/6, 7/8, etc... so it can be anything, analogue or digitals. Then in total mix I use the loopback button on the output mixer, and in ableton I create audio track monitoring inputs 5/6, 7/8, etc ... Please, can someone confirm I understood correctly ? hum that's great, but I would need 16 channels so I can route 8 stereo tracks (so 16 channels) from maschine to ableton live hmm
Also, Timur,
at the moment, I need to aggregate soundflower with my audio sound card, because in ableton live, I need it to receive audio from both maschine (which is software, so through virtual connections), and also my external compressor. If I only choose sound flower, I cannot receive the inputs from my audio interface. And indeed, with jack osx you can use everything without aggregating, but I had some stability problems. But it might be because of my audio interface, m-audio fast track pro, the drivers are terrible ( I can't record at 24bits because I'm using 4 analogue outputs at a time... terrible), there is sometimes good sound, sometimes it's like a bit reducer, crack, pop, etc...
that's why i'm interested in RME with their totalmix and apparently very stable drivers.
anyway, please, confirm that I understood how I would set up totalmix.
cheers wink
Edit : by the way, I checked on the product page of the fireface UC, it says 18ins and 18 outs, but I can see only 8 outs and 1 digital. and why I saw somewhere that it's "32 Channels" ?
Hey there! Yes you understood correctly. There are 18 inputs + 18 outputs on (=36 channels), 8x analog + 8x ADAT + 2x SPDIF. You can use any of these I/O pairs to use the loopback.
It's been a while since I checked Soundflower, does it not offer to route hardware inputs to software/virtual outputs? And why don't you use Maschine as a plugin to get away from the whole virtual cabling?
hey timur. thanks again for all the info.
Hum so 18 channels, I need 4 real outs (2 for main monitors, 2 for stereo ext. compressor), and then normally 16 for maschine (8groups stereos)... hum it would be short of 2 channels (actually 4 cause I want to connect headphones too) hmm ... I guess the solution to this would be to take a larger sound interfece such as the UFX or the 800... but they are both too much for my need... and the UFX is much more expensive, the 800 is already 300 or 400 euro more ! hmm
Yea souldflower is purely virtual. Jacks osx can do it though.
Also, maschine as a plug-in is great, but lack of some features that standalone offers, such as the autonomy of play/stop/rec (which in my opinion and lots of people using it and complaining on NI forum, is quite important for the workflow, to get this hands on hardware feeling), also in plug-in you cannot fullscreen the maschine software... And also, I got used to sample directly from iTunes or even youtube to get micro-samples, through soundflower/jackosx. So even if I was using maschine as a plug-in, I would still need to use soundflower/jackosx for that as well.
So well, not sure what to do then ... I definitely want another audio interface anyway. maybe using a RME with sound flower ... not sure yet...
Thanks Timur ! wink
Trying to figure out exactly what you need to do here?
Do you need 8 physical hardware outputs for maschine?
Are you sending these to out to a separate mixer for manipulation?
How many physical outputs do you need for Ableton?
Are you trying to sample live inputs into Ableton and/or maschine while performing?
Is the source your trying to sample just virtual i.e., from itunes or to and from Ableton/maschine?
How is the hardware compressor being used?
Thanks Chris
Chris Ludwig
www.facebook.com/RMEAmericas
Twitter @RMEAmericas
Hi chris,
Thanks for all the questions smile
so here is it :
maschine 16 channel (8 stereo tracks) virtual outs (sound flower) ->ableton live (8 stereos ins tracks from maschine, and a ton more directly inside ableton live) -> master bus -> 3/4 outs to compressor -> 1/2 ins sound card -> go back to master bus in ableton live -> 1/2 outs speakers.
- no, if possible 8 stereos virtual outputs (so 16 virtual channels)
- so far, I do all my mix in my DAW
- 6 (1/2 speakers, 3/4 compressor, and a stereo for headphones)
- yes, I want to sample itunes/youtube/etc... directly to maschine. And I want to jam on maschine and record directly in ableton live.
- Yes it's virtual
- compressor is used as an external plug-in in ableton live on the master bus. signal goes out 3/4 of the sound card, goes to compressor, then comes back ins 1/2 and goes back on the master bus in ableton live.
all in all, not so complicated, but still not the usual simple home studio settings.
I do that to bypass some technical restriction from maschine (no side chain for example). Also, I can compose in maschine, and already do a mix inside ableton Live, then I can record directly or jam and record. Eventually, I would like to do the same with live, and route maschine + ableton live to another daw like logic or pro tools. But not for the moment, that just something I'll like to do soon.
finally, I want to change my m-audio fast track pro because I'm not happy with it (for lots of good reasons).
from what timur said, if I understood correctly, I could almost do that with the RME fireface UC but I will still have 2 or 4 channels missing (depending if I want to use headphones or not). The Fireface ufx or 800 could do it, but I find it a waste to have so many inputs/outputs and using actually none but only virtually.
Please, tell me chris what do you think and you have any suggestion.
Cheers
Did you try both flavors of Jack already, Jack 1 (0.121.2) vs. Jack 2 (1.9.7) might give different results as far as stability is concerned.
well I'm under mac osx so it's only one version called jackosx. Today I tried it back and yea it's kind of better than sound flower.
can we use an RME sound card such as the baby face or UC with jackosx ?
