Topic: Babyface problem with gain control AN2
Hi:
I bought a Babyface serial 7A86160800A44C8 through Amazon.com a couple of months ago. (It came with a small scratch but I didn't mind.)
I have never been able to control gain in AN 2. When I open Totalmix and adjust gain with the Babyface control wheel (or with the gain software button in Totalmix) suddenly gain boosts to maximum and no matter what the software button is showing. If I move the Babyfece wheel to try to lower the gain of AN2 Hardware output in Totalmix goes to null automatically but audibly . If I reset Totalmix completly the problem appears again.
Thank in advance for your help. (You may answer auf Deutsch as well)
Rolando
My Babyface 32142501 has a firmware v. 184 and driver v.1.59. I attached 2 dynamic mikes SM58.
My PC configuration is as following:
Model Name: MacBook Pro
Model Identifier: MacBookPro2,2
Processor Name: Intel Core 2 Duo
Processor Speed: 2.16 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 4 MB
Memory: 2 GB
Bus Speed: 667 MHz
Boot ROM Version: MBP22.00A5.B07
SMC Version (system): 1.12f5
Network adapters: Marvell Yukon Gigabit Adapter 88E8053 Singleport Copper SA:
Graphic card: ATY,RadeonX1600
Other installed soundcards: No
