Topic: HDSPe MADI & ADI-8QSM & ADI-642 support 16-channel 24-bit @ 192-kHz ?
I know HDSPe MADI record/playback 16-channel 24-bit @ 192-kHz
I presume the ADI-8QS with the IA-64 option can handle 8-channel 24-bit @ 192-kHz from a MADI connection
The one I'm in doubt is the ADI-642 since I don't see anything clearly stated on the manual about it.
Can anyone confirm I will be able to run 16-channel 24-bit @ 192-kHz to/from the HDSPe MADI via the 642 (routing) to 2 ADI-8QS with the MADI option without any surprises ?
Re: HDSPe MADI & ADI-8QSM & ADI-642 support 16-channel 24-bit @ 192-kHz ?
No problem. Note that the 642 is not needed for the 16 channels/routing, only if you need additional AES I/Os.
