Topic: FF800, Sonar 8.5 question about routing
Hi there,
I wanted to check on here to make sure i don't do something stupid and blow up my FF800.
What i'd like to do...is to take 5 drum tracks (already recorded) and send them out to an FX pedal, and then back into an input on the FF800 to record the drums with the new fx. This is probably easy, but I wanted to double check on here before i do something stupid.
Would it be as easy as
1. assign the drum bus track output to a specific output on the back of the FF800
2. plug the 1/4 inch cable from the said output on the back of the fFF800 to my fx pedal
3. plug 1/4 inch cable into one of the inputs on the front of the FF800
4. create and arm a new track in sonar with the input set to the sfx drum signal
5. press record?
Thanks so much in advance!!
Kaiya
