Topic: Pro Tools 9 and RME FireFace 800
I am using two RME Fireface 800 Interfaces and linked them using the Firewire 800 ports and connect them to the computer running Windows 7 Ultimate 64 bit using Firewire 400.  I bought and installed Pro Tools 9 to use with the interfaces for multitrack recording taking signal from the Yamaha M7 via ADAT.  When I record enable Pro Tools, I notice that Pro Tools is not picking up signal from the 2nd Interface, but I can see the signal coming in on the FireFace Mixer, how do I make Pro Tools see the signal from the 2nd interface?
Re: Pro Tools 9 and RME FireFace 800
http://www.rme-audio.de/forum/viewtopic.php?id=1281
Also, don't forget the 32 channel limit on PT9. Each FF800 has 28 channels, so you won't get very far this way. A better idea would be to use one FF800 via ADAT.
http://youtu.be/Oibj81QIq4s
